Selling my spare usdm rear seat
No burns, cuts or holes etc.
Slight fade on the top edge
Excuse the "dents" they are stacked in the trunk of my itr.
Quick clean with some woolite and they will look great
$400 plus shipping, PayPal goods and services only.
FS: Usdm rear seat
Re: FS: Usdm rear seat
Where are they located? Potential buyers would definitely like to know.
What's the story on your ITR? Looks partially disassembled. Engine on the stand and transmission on the ground I believe.
FYI have to be careful how you store seats 25 year old foam doesn't have the memory it once did and there is a good chance it won't bounce back
@USDMITR
- Badge Number: searching
Opps thanks for the good eye
Seats are in Vancouver Canada and I have very good shipping connections
Spun bearing in April of 2021 and have been waiting/searching for a compent machine shop for the rebuild
Appreciate the heads up, the seats have already come back and with the help of a hair dryer they will look like nothing happened. Had a set of leather seats in far worse shape and they came back with some heat and massaging
Have you sourced a crankshaft? You will definitely need one if you spun a bearing and most likely you will need one rod at minimum.
Yes I was fortunate and found 3 usdm itr cranks and 2 gsr cranks, spare CDM/usdm c5 block, Connecting rods were available new from Acura so I ordered all four.
- Dc2-ProductionS
- Badge Number: 97-00012
Do you have a R crank available for purchase? PM sent
Users browsing this forum: ITR98 and 3 guests
