Hi there,
Does anyone have this part for b18c1 Integra gsr water hose for sale??
Honda water hose
79722-ST7-A00
water hose 79722-ST7-A00 (b18c)
- 79722-ST7-A00.PNG (103.82 KiB) Viewed 3780 times
- oddomatik
- Badge Number: 98-0542
Re: water hose 79722-ST7-A00 (b18c)
Is OEM necessary for your needs? Any auto parts store can help you find an aftermarket replacement. It's a basic 90 degree bend, which should be found easily. You could also find a similar size/shape one and cut it to length, just need to ensure the diameter is correct.
ACDelco 14100S
Gates 18792
^^ Appear to be the closest match. THIS SITE was most helpful in narrowing it down, just go do a visual check in person to make sure they're what you need.
ACDelco 14100S
Gates 18792
SpecE30 | RAM 3500 | CB550
Hi oddomatik,
I found out that there are other Honda's that have the same size/shape hose
