water hose 79722-ST7-A00 (b18c)
All non-ITR/CTR Cars and Parts can be posted for sale here.
Whys0serious
Post by Whys0serious » Sun Aug 06, 2023 9:36 pm
Hi there,
Does anyone have this part for b18c1 Integra gsr water hose for sale??
Honda water hose
79722-ST7-A00
oddomatik
Badge Number: 98-0542
Re: water hose 79722-ST7-A00 (b18c)
Post by oddomatik » Mon Aug 07, 2023 11:40 am
Is OEM necessary for your needs? Any auto parts store can help you find an aftermarket replacement. It's a basic 90 degree bend, which should be found easily. You could also find a similar size/shape one and cut it to length, just need to ensure the diameter is correct.
ACDelco 14100S
Gates 18792
^^ Appear to be the closest match. THIS SITE was most helpful in narrowing it down, just go do a visual check in person to make sure they're what you need.
ITR (98-0542) | NA1 NSX | 240z | 190E 2.3-16V
SpecE30 | RAM 3500 | CB550
Whys0serious
Post by Whys0serious » Fri Aug 11, 2023 12:02 am
Hi oddomatik,
I found out that there are other Honda's that have the same size/shape hose
