Radiator Options with stock fans?
Re: Radiator Options with stock fans?
Post by aw614 » Sat Mar 02, 2019 1:52 pm
Just to update this thread, being paranoid about the temps for the track in Florida, I decided to swap out my denso oem replacement with Koyo V083146. With the stock fans and JDM 4-1 header and heat shield clear without any issue
Pic:
ImageDSC_0093 by Andrew Wong, on Flickr
Post by coolhandluke » Sat Mar 02, 2019 3:14 pm
aw614 wrote: Sat Mar 02, 2019 1:52 pm Just to update this thread, being paranoid about the temps for the track in Florida, I decided to swap out my denso oem replacement with Koyo V083146. With the stock fans and JDM 4-1 header and heat shield clear without any issue
Excellent information, thank you for sharing.
Post by RTW DC2R » Sat Mar 02, 2019 3:42 pm
My koyo worked fine with stock fans, but had to tweak the shroud to work with my Toda rep header. Switched to Spal fans and have plenty of clearance.
Post by aklackner » Sat Mar 02, 2019 10:16 pm
Koyo with OEM shroud looked good but when driving over time dug into AC compressor line fitting.
Post by jayhaire » Sat Mar 02, 2019 11:34 pm
aklackner wrote: Sat Mar 02, 2019 10:16 pm Koyo with OEM shroud looked good but when driving over time dug into AC compressor line fitting.
I had a similar thing happen to my AC line while using a Koyo and OEM fans. It was a rough discovery (hot summer afternoon, stuck in traffic on way to GingerMan) when the AC failed to work.
I replaced the line and the fans with slim Spal fans. No issues since then.
Post by aw614 » Sun Mar 03, 2019 3:14 pm
Guess is time to pull the dremel to trim that part of the shroud. Mine is also touching that part of the ac line
