Gents,
Looking at the FSM, page 20-66, describes the process of installing an adhesive into the groove of the rear window molding prior to installing it, then you install it onto the glass, wipe it down, let it cure, and then later install the glass onto the chassis.
The FSM does not specify what kind of adhesive. Does anyone know what is appropriate for the molding to the glass? Should it just be the same window adhesive for the glass to the chassis?
Thanks in advance!
Adhesive for rear hatch molding to glass
- rear_glass_adhesive.png (529.96 KiB) Viewed 3319 times
