USDM vs JDM Exhaust Manifold - fit the same or different?
I believe it's a 4-1 on the JDM and a 4-2-1 on the USDM? Does thee JDM fit on the US car's?
Thanks!
Thanks!
Re: USDM vs JDM Exhaust Manifold - fit the same or different?
'96 spec jdm has a cast 4-2-1. Everyone forgets that. Unsure of that's the same as the usdm, but i think there is a difference in cat length. Might be made up on the exhaust side.
Neither 96 or 98+ will connect to a usdm cat, too short.
Does JDM heat shield fit on USDM header?
- Purplepassiongsr
What is everyone using for a high flow cat these days? Looking to get one made up in jdm length. The jdm cat I picked up doesn't have an 02 sensor.
I bought a GESI cat and also a 2.5in adjustable test pipe for the piping so I could get it eventually welded together with flanges.
J's racing sells a test pipe in the JDM length with brackets to fit the appropriate oem cat shields for $200. The shields can be purchased from Amayama for about $25 for each piece.
- Purplepassiongsr
Thanks for the feedback gents
